Update translations
Update translations
diff --git a/config/locales/client.be.yml b/config/locales/client.be.yml
new file mode 100644
index 0000000..33cca6c
--- /dev/null
+++ b/config/locales/client.be.yml
@@ -0,0 +1,20 @@
+# encoding: utf-8
+# Never edit this file. It will be overwritten when translations are pulled from Transifex.
+# To work with us on translations, join this project:
+# https://www.transifex.com/projects/p/discourse-org/
+be:
+  js:
+    explorer:
+      types:
+        bool:
+          'yes': "Так"
+          'no': "Не"
+      export: "экспарт"
+      save: "Захаваць"
+      edit: "Рэдагаваць"
+      delete: "Выдаліць"
+      query_description: "апісанне"
+      reset_params: "скінуць"
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index 07aa5d6..de2065e 100644
--- a/config/locales/client.ca.yml
+++ b/config/locales/client.ca.yml
@@ -7,22 +7,54 @@
 ca:
   js:
+    errors:
+      explorer:
+        no_semicolons: "Elimina els punts i coma de la consulta."
+        dirty: "Cal desar la consulta abans d'executar-la"
     explorer:
+      admins_only: "L'explorador de dades sols és disponible per a administradors."
+      title: "Explorador de dades"
+      create: "Crea'n un de nou"
       create_placeholder: "Nom de consulta..."
+      description_placeholder: "Introduïu una descripció aquí"
       import:
         label: "Importa"
+        modal: "Importa una consulta"
       schema:
+        title: "Esquema de base de dades"
         filter: "Cerca..."
+        sensitive: "El contingut d’aquesta columna pot contenir informació particularment sensible o privada. Tingueu precaució quan utilitzeu el contingut d’aquesta columna."
+        type_help: "<a href='http://www.postgresql.org/docs/9.3/static/datatype.html#DATATYPE-TABLE' target='_blank'>Tipus</a>"
       types:
         bool:
           'yes': "Sí"
           'no': "No"
+          null_: "Nul"
       export: "Exporta"
       save: "Desa els canvis"
+      saverun: "Desa els canvis i executa"
+      run: "Executa"
+      undo: "Descarta els canvis"
       edit: "Edita"
-      delete: "Esborra"
+      delete: "Suprimeix"
+      recover: "Restaura la consulta"
       download_json: "JSON"
       download_csv: "CSV"
+      others_dirty: "Una consulta té canvis no desats que es perdran si continueu navegant."
+      run_time: "Consulta completada en {{value}} ms."
+      result_count:
+        one: "resultat %{count}."
+        other: "Resultats %{count}."
+      max_result_count:
+        one: "Mostrant els millors %{count}resultats."
+        other: "Mostrant els millors %{count} resultats."
+      query_name: "Consulta"
       query_description: "Descripció"
+      query_time: "Darrera execució"
+      query_user: "Creat per"
+      column: "Columna {{number}}"
+      explain_label: "Hi incloem pla de consulta?"
+      save_params: "Estableix valors per defecte"
       reset_params: "Reinicia"
       search_placeholder: "Cerca..."
+      no_search_results: "Ho sentim, no hem trobat cap resultat que coincideixi amb el vostre text."
diff --git a/config/locales/client.pl_PL.yml b/config/locales/client.pl_PL.yml
index ba9f722..0da2b51 100644
--- a/config/locales/client.pl_PL.yml
+++ b/config/locales/client.pl_PL.yml
@@ -7,19 +7,58 @@
 pl_PL:
   js:
+    errors:
+      explorer:
+        no_semicolons: "Usuń średniki z zapytania."
+        dirty: "Musisz zapisać zapytanie zanim je wykonasz."
     explorer:
+      admins_only: "Eksplorator danych jest dostępny wyłącznie dla administratorów."
+      title: "Eksplorator danych"
+      create: "Stwórz nowy"
+      create_placeholder: "Nazwa zapytania…"
+      description_placeholder: "Wprowadź opis zapytania"
       import:
         label: "Import"
+        modal: "Importuj zapytanie"
       schema:
+        title: "Schemat bazy danych"
         filter: "Wyszukiwanie..."
+        sensitive: "Zawartość tej kolumny może zawierać szczególnie wrażliwe lub prywatne dane. Prosimy o zachowanie ostrożności przy używaniu tych danych."
+        type_help: "<a href='http://www.postgresql.org/docs/9.3/static/datatype.html#DATATYPE-TABLE' target='_blank'>Typy</a>"
       types:
         bool:
           'yes': "Tak"
           'no': "Nie"
+          null_: "Null"
       export: "Eksport"
       save: "Zapisz zmiany"
+      saverun: "Zapisz zmiany i wykonaj"
+      run: "Wykonaj"
+      undo: "Odrzuć zmiany"
       edit: "Edytuj"
       delete: "Usuń"
+      recover: "Przywróć zapytanie"
+      download_json: "JSON"
+      download_csv: "CSV"
+      others_dirty: "Zapytanie ma niezapisane zmiany, które utracisz, jeśli przejdziesz w inne miejsce."
+      run_time: "Zapytanie wykonane w {{value}} ms."
+      result_count:
+        one: "%{count}wynik."
+        few: "%{count}wyniki."
+        many: "%{count}wyników."
+        other: "%{count}wyników."
+      max_result_count:
+        one: "Pokazywanie %{count} pierwszego wyniku."
+        few: "Pokazywanie %{count} pierwsze wyniki."
+        many: "Pokazywanie %{count} pierwszych wyników."
+        other: "Pokazywanie %{count} pierwszych wyników."
+      query_name: "Zapytanie"
       query_description: "Opis"
+      query_time: "Ostatnio wykonano"
+      query_user: "Stworzone przez"
+      column: "Kolumna {{number}}"
+      explain_label: "Dołączyć plan zapytania?"
+      save_params: "Ustaw domyślne"
       reset_params: "Przywróć"
       search_placeholder: "Wyszukiwanie..."
+      no_search_results: "Nie znaleziono żadnych wyników."
diff --git a/config/locales/client.sw.yml b/config/locales/client.sw.yml
index fd7f48c..8993995 100644
--- a/config/locales/client.sw.yml
+++ b/config/locales/client.sw.yml
@@ -23,7 +23,7 @@ sw:
       schema:
         title: "Mpango wa kuhifadhidata"
         filter: "Tafuta..."
-        sensitive: "Taarifa zilizomo ndani ya safuwima zinaweza kuwa za kibinafsi au zinazozingatiwa. Tafadhali kuwa makini na mwangalifu unapotumia hizi taarifa.  "
+        sensitive: "Taarifa zilizomo ndani ya safuwima zinaweza kuwa za kibinafsi au zinazozingatiwa. Tafadhali kuwa makini na mwangalifu unapotumia hizi taarifa. "
         type_help: "<a href='http://www.postgresql.org/docs/9.3/static/datatype.html#DATATYPE-TABLE' target='_blank'>Aina</a>"
       types:
         bool:
diff --git a/config/locales/server.be.yml b/config/locales/server.be.yml
index 0000000..59ac412
--- /dev/null
+++ b/config/locales/server.be.yml
@@ -0,0 +1,8 @@
+# encoding: utf-8
+be: {}
diff --git a/config/locales/server.ca.yml b/config/locales/server.ca.yml
index 79b1db0..9285eab 100644
--- a/config/locales/server.ca.yml
+++ b/config/locales/server.ca.yml
@@ -7,4 +7,4 @@
 ca:
   site_settings:
-    data_explorer_enabled: "Activa l'Explorador de Dades a /admin/plugins/explorer"
+    data_explorer_enabled: "Activa l'Explorador de dades en /admin/plugins/explorer"
GitHub sha: 1f1afd0d
