Update translations
Update translations
index 5c2528f..100205b 100644
--- a/Gemfile.lock
+++ b/Gemfile.lock
@@ -1,6 +1,6 @@
 GIT
   remote: https://github.com/discourse/translations-manager.git
-  revision: 7fe7d67f53fe917341b7abfb101b529be264fc8d
+  revision: 927edce96b5bb1d7eb4f3f66bc8d77b0867639a2
   specs:
     translations-manager (0.4)
diff --git a/config/locales/client.be.yml b/config/locales/client.be.yml
new file mode 100644
index 0000000..b4000c4
--- /dev/null
+++ b/config/locales/client.be.yml
@@ -0,0 +1,12 @@
+# encoding: utf-8
+# Never edit this file. It will be overwritten when translations are pulled from Transifex.
+# To work with us on translations, join this project:
+# https://www.transifex.com/projects/p/discourse-org/
+be:
+  js:
+    solved:
+      topic_status_filter:
+        all: "усе"
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index 3785155..167be75 100644
--- a/config/locales/client.ca.yml
+++ b/config/locales/client.ca.yml
@@ -10,10 +10,24 @@ ca:
     notifications:
       alt:
         solved:
-          accepted_notification: "Acceptat"
+          accepted_notification: "acceptat"
     solved:
       title: "Solucionat"
+      allow_accepted_answers: "Permet que el propietari del tema i l'equip responsable marquin una resposta com a solució"
+      accept_answer: "Seleccioneu aquesta resposta si resol el problema"
+      has_no_accepted_answer: "Aquest tema no té cap solució"
+      unaccept_answer: "Desseleccioneu aquesta resposta si ja no resol el problema"
       accepted_answer: "Solució"
       solution: "Solució"
+      solution_summary:
+        one: "solució"
+        other: "solucions"
+      accepted_html: "{{icon}} Resolt <span class='by'>per <a href data-user-card='{{username_lower}}'>{{username}}</a></span> en la <a href='{{post_path}}' class='back'>publicació # {{post_number}}</a>"
+      accepted_notification: "<p><span>{{username}}</span> {{description}}</p>"
         all: "tots"
+        solved: "resolt"
+        unsolved: "no resolt"
+    topic_statuses:
+      solved:
+        help: "Aquest tema té una solució"
diff --git a/config/locales/client.pl_PL.yml b/config/locales/client.pl_PL.yml
index 6cb8aeb..8c7d545 100644
--- a/config/locales/client.pl_PL.yml
+++ b/config/locales/client.pl_PL.yml
@@ -19,8 +19,17 @@ pl_PL:
       unaccept_answer: "Odznacz jeśli ta odpowiedź nie rozwiązuje już problemu"
       accepted_answer: "Zaakceptowana odpowiedź"
       solution: "Rozwiązanie"
+      solution_summary:
+        one: "rozwiązanie"
+        few: "rozwiązania"
+        many: "rozwiązania"
+        other: "rozwiązania"
+      accepted_html: "{{icon}}rozwiązane <span class='by'> przez <a href data-user-card='{{username_lower}}'>{{username}}</a></span> we <a href='{{post_path}}' class='back'>wpisie #{{post_number}}</a>"
+      accepted_notification: "<p><span>{{username}}</span>{{description}}</p>"
         all: "wszystkie"
+        solved: "rozwiązano"
+        unsolved: "nierozwiązano"
     topic_statuses:
       solved:
         help: "Ten temat ma zaakceptowane rozwiązanie"
diff --git a/config/locales/server.be.yml b/config/locales/server.be.yml
index 0000000..cf35ce4
--- /dev/null
+++ b/config/locales/server.be.yml
@@ -0,0 +1,12 @@
+# encoding: utf-8
+be:
+  reports:
+    accepted_solutions:
+      xaxis: "дзень"
+      yaxis: "агульны"
diff --git a/config/locales/server.ca.yml b/config/locales/server.ca.yml
index 87f5593..6315e13 100644
--- a/config/locales/server.ca.yml
+++ b/config/locales/server.ca.yml
@@ -6,7 +6,20 @@
 ca:
+  site_settings:
+    solved_enabled: "Activa el connector de resolts. Permet als usuaris seleccionar solucions per als temes."
+    allow_solved_on_all_topics: "Permet als usuaris seleccionar solucions en tots els temes (per defecte, ho controleu editant categories)"
+    accept_all_solutions_trust_level: "Nivell mínim de confiança necessari per a acceptar solucions sobre qualsevol tema (encara que no sigui OP)"
+    empty_box_on_unsolved: "Mostra un quadre buit al costat dels temes no resolts"
+    solved_quote_length: "Nombre de caràcters que se citen quan es mostri la solució sota la primera publicació"
+    solved_topics_auto_close_hours: "Tanca automàticament el tema (n) hores després de la darrera resposta una vegada el tema s'hagi marcat com a resolt."
+    show_filter_by_solved_status: "Mostra un menú desplegable per a filtrar una llista de temes per estat de resolució."
   reports:
     accepted_solutions:
+      title: "Solucions acceptades"
       xaxis: "Dia"
       yaxis: "Total"
+  solved:
+    no_solutions:
+      self: "Encara no teniu solucions acceptades."
+      others: "No hi ha solucions acceptades."
diff --git a/config/locales/server.pl_PL.yml b/config/locales/server.pl_PL.yml
index 8bb1994..884790a 100644
--- a/config/locales/server.pl_PL.yml
+++ b/config/locales/server.pl_PL.yml
@@ -7,9 +7,13 @@
 pl_PL:
   site_settings:
+    solved_enabled: "Aktywuj wtyczkę solved, zezwól użytkownikom wybierać rozwiązania w tematach"
     allow_solved_on_all_topics: "Pozwól oznaczać użytkownikom wszystkie tematy jako rozwiązane (domyślnie tylko dla wybranych kategorii w ich ustawieniach)"
+    accept_all_solutions_trust_level: "Minimalny poziom zaufania wymagany do zaakceptowania rozwiązania w każdym temacie (nawet jeśli nie jest się jego autorem)"
     empty_box_on_unsolved: "Wyświetl puste pole obok nierozwiązanych tematów"
     solved_quote_length: "Liczba znaków do wyświetlenia przy wyświetlaniu rozwiązania pod pierwszym wpisem"
+    solved_topics_auto_close_hours: "Zamknij temat automatycznie po (n) godzinach od ostatniej odpowiedzi, gdy temat został oznaczony jako rozwiązany"
+    show_filter_by_solved_status: "Pokaż rozwinięcie, aby filtrować listę tematów po statusie rozwiązania"
   reports:
     accepted_solutions:
       title: "Zaakceptowane rozwiązania"
diff --git a/config/locales/server.ru.yml b/config/locales/server.ru.yml
index 1048699..870973d 100644
--- a/config/locales/server.ru.yml
+++ b/config/locales/server.ru.yml
@@ -7,7 +7,7 @@
 ru:
   site_settings:
-    solved_enabled: "Включить  плагин и разрешить пользователям отмечать выбранные,  решенные ответы"
+    solved_enabled: "Включить плагин и разрешить пользователям отмечать выбранные, решенные ответы"
     allow_solved_on_all_topics: "Разрешить пользователям отмечать ответы в темах (управляется в свойствах раздела)"
     accept_all_solutions_trust_level: "Минимальный уровень доверия, необходимый для принятия решений по любой теме (даже если не OP)"
     empty_box_on_unsolved: "Показывать пустое поле рядом с нерешенными темами"
GitHub sha: 33a28ced
