Update translations
Update translations
diff --git a/config/locales/client.ar.yml b/config/locales/client.ar.yml
index 26b5c00..52abfe6 100644
--- a/config/locales/client.ar.yml
+++ b/config/locales/client.ar.yml
@@ -21,6 +21,7 @@ ar:
       save: "احفظ التعديلات"
       edit: "عدّل"
       delete: "أحذف"
+      query_groups: "المجموعات"
       query_description: "الوصف"
       reset_params: "اعادة تعيين"
       search_placeholder: "بحث..."
diff --git a/config/locales/client.be.yml b/config/locales/client.be.yml
index 33cca6c..c16848f 100644
--- a/config/locales/client.be.yml
+++ b/config/locales/client.be.yml
@@ -16,5 +16,6 @@ be:
       save: "Захаваць"
       edit: "Рэдагаваць"
       delete: "Выдаліць"
+      query_groups: "групы"
       query_description: "апісанне"
       reset_params: "скінуць"
diff --git a/config/locales/client.bg.yml b/config/locales/client.bg.yml
index 16daf5c..18e57ff 100644
--- a/config/locales/client.bg.yml
+++ b/config/locales/client.bg.yml
@@ -20,5 +20,6 @@ bg:
       save: "Запази промените"
       edit: "Редактирай"
       delete: "Изтрий"
+      query_groups: "Групи"
       query_description: "Описание"
       search_placeholder: "Търсене ... "
diff --git a/config/locales/client.bs_BA.yml b/config/locales/client.bs_BA.yml
index f64a940..9c2a72b 100644
--- a/config/locales/client.bs_BA.yml
+++ b/config/locales/client.bs_BA.yml
@@ -14,8 +14,13 @@ bs_BA:
         bool:
           'yes': "Da"
           'no': "Ne"
+      export: "Izvoz"
       save: "Spremiti promjene"
       edit: "Izmijeni"
       delete: "Delete"
+      query_groups: "Grupa"
       query_description: "Opis"
+      reset_params: "Resetovati"
       search_placeholder: "Pretraga..."
+    group:
+      reports: "Izvještaji"
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index de2065e..e6e3236 100644
--- a/config/locales/client.ca.yml
+++ b/config/locales/client.ca.yml
@@ -23,7 +23,7 @@ ca:
       schema:
         title: "Esquema de base de dades"
         filter: "Cerca..."
-        sensitive: "El contingut d’aquesta columna pot contenir informació particularment sensible o privada. Tingueu precaució quan utilitzeu el contingut d’aquesta columna."
+        sensitive: "El contingut d'aquesta columna pot contenir informació particularment sensible o privada. Tingueu precaució quan utilitzeu el contingut d'aquesta columna."
         type_help: "<a href='http://www.postgresql.org/docs/9.3/static/datatype.html#DATATYPE-TABLE' target='_blank'>Tipus</a>"
       types:
         bool:
@@ -43,12 +43,14 @@ ca:
       others_dirty: "Una consulta té canvis no desats que es perdran si continueu navegant."
       run_time: "Consulta completada en {{value}} ms."
       result_count:
-        one: "resultat %{count}."
-        other: "Resultats %{count}."
+        one: "%{count} resultat."
+        other: "%{count} resultats."
       max_result_count:
-        one: "Mostrant els millors %{count}resultats."
-        other: "Mostrant els millors %{count} resultats."
+        one: "Mostrant el millor %{count} resultat."
+        other: "Es mostren els millors %{count} resultats."
       query_name: "Consulta"
+      query_groups: "Grups"
+      report_name: "Report"
       query_description: "Descripció"
       query_time: "Darrera execució"
       query_user: "Creat per"
@@ -58,3 +60,5 @@ ca:
       reset_params: "Reinicia"
       search_placeholder: "Cerca..."
       no_search_results: "Ho sentim, no hem trobat cap resultat que coincideixi amb el vostre text."
+    group:
+      reports: "Reports"
diff --git a/config/locales/client.cs.yml b/config/locales/client.cs.yml
index efdc05a..5a6d85d 100644
--- a/config/locales/client.cs.yml
+++ b/config/locales/client.cs.yml
@@ -24,6 +24,7 @@ cs:
       delete: "Smazat"
       download_json: "JSON"
       download_csv: "CSV"
+      query_groups: "Skupiny"
       query_description: "Popis"
       column: "Sloupec {{number}}"
       reset_params: "obnovit výchozí"
diff --git a/config/locales/client.da.yml b/config/locales/client.da.yml
index ae00749..5c8c075 100644
--- a/config/locales/client.da.yml
+++ b/config/locales/client.da.yml
@@ -20,6 +20,9 @@ da:
       save: "Gem ændringer"
       edit: "Rediger"
       delete: "Slet"
+      query_groups: "grupper"
       query_description: "Beskrivelse"
       reset_params: "Nulstil"
       search_placeholder: "Søg..."
+    group:
+      reports: "Rapporter"
diff --git a/config/locales/client.de.yml b/config/locales/client.de.yml
index abd59d6..dbd29ab 100644
--- a/config/locales/client.de.yml
+++ b/config/locales/client.de.yml
@@ -49,6 +49,8 @@ de:
         one: "Zeige die ersten %{count} Ergebnisse."
         other: "Zeige die ersten %{count} Ergebnisse."
       query_name: "Anfrage"
+      query_groups: "Gruppen"
+      report_name: "Bericht"
       query_description: "Beschreibung"
       query_time: "Letzter Lauf"
       query_user: "Erstellt von"
@@ -58,3 +60,5 @@ de:
       reset_params: "Zurücksetzen"
       search_placeholder: "Suche…"
       no_search_results: "Sorry, wir konnten keine Ergebnisse finden, die deinem Text entsprechen."
+    group:
+      reports: "Berichte"
diff --git a/config/locales/client.el.yml b/config/locales/client.el.yml
index 654d54c..672e9be 100644
--- a/config/locales/client.el.yml
+++ b/config/locales/client.el.yml
@@ -20,6 +20,7 @@ el:
       save: "Αποθήκευση Αλλαγών"
       edit: "Επεξεργασία"
       delete: "Σβήσιμο"
+      query_groups: "Ομάδες"
       query_description: "Περιγραφή"
       reset_params: "Επαναφορά"
       search_placeholder: "Αναζήτηση..."
diff --git a/config/locales/client.es.yml b/config/locales/client.es.yml
index 15dfcf4..88de7d0 100644
--- a/config/locales/client.es.yml
+++ b/config/locales/client.es.yml
@@ -9,52 +9,56 @@ es:
   js:
     errors:
       explorer:
-        no_semicolons: "Eliminar los puntos y comas de la consulta."
+        no_semicolons: "Eliminar los punto y coma de la consulta."
         dirty: "Debes guardar la consulta antes de ejecutarla."
     explorer:
-      admins_only: "El data explorer esta disponible únicamente para administradores."
-      title: "Data Explorer"
-      create: "Crear Nuevo"
+      admins_only: "El explorador de datos solo esta disponible para administradores."
+      title: "Explorador de datos"
+      create: "Crear nuevo"
       create_placeholder: "Nombre de la consulta..."
-      description_placeholder: "introduce una descripción aquí"
+      description_placeholder: "Ingresa una descripción aquí"
       import:
         label: "Importar"
-        modal: "Importar una Consulta"
+        modal: "Importar una consulta"
       schema:
-        title: "Esquema de Base de Datos"
+        title: "Esquema de base de datos"
         filter: "Buscar..."
-        sensitive: "Los contenidos de esta parte pueden incluir información sensible o privada. Por favor, ten cuidado cuando visualices estos contenidos."
+        sensitive: "Los contenidos de esta parte pueden incluir información particularmente sensible o privada. Por favor, ten cuidado cuando utilices estos contenidos."
         type_help: "<a href='http://www.postgresql.org/docs/9.3/static/datatype.html#DATATYPE-TABLE' target='_blank'>Tipos</a>"
       types:
         bool:
-          'yes': "Si"
+          'yes': "Sí"
           'no': "No"
-          null_: "Null"
+          null_: "Nulo"
       export: "Exportar"
-      save: "Guardar Cambios"
+      save: "Guardar cambios"
       saverun: "Guardar cambios y ejecutar"
       run: "Ejecutar"
-      undo: "Deshacer cambios"
+      undo: "Descartar cambios"
       edit: "Editar"
-      delete: "Borrar"
+      delete: "Eliminar"
       recover: "Recuperar consulta"
       download_csv: "CSV"
-      others_dirty: "Una consulta tiene cambios no guardados que se perderán si salís."
+      others_dirty: "Una consulta tiene cambios no guardados que se perderán si sales."
       result_count:
GitHub sha: c5874847
