Update translations
Update translations
index 100205b..705b4bd 100644
--- a/Gemfile.lock
+++ b/Gemfile.lock
@@ -1,8 +1,8 @@
 GIT
   remote: https://github.com/discourse/translations-manager.git
-  revision: 927edce96b5bb1d7eb4f3f66bc8d77b0867639a2
+  revision: 68bbf2a99412638b73057935c89c6b2e1945e092
   specs:
-    translations-manager (0.4)
+    translations-manager (0.5)
 GEM
   specs:
diff --git a/config/locales/client.ar.yml b/config/locales/client.ar.yml
index 74bc4ee..7db7f71 100644
--- a/config/locales/client.ar.yml
+++ b/config/locales/client.ar.yml
@@ -21,6 +21,8 @@ ar:
       solution: "الحل"
       topic_status_filter:
         all: "الكل"
+        solved: "تم حله"
+        unsolved: "غير محلول"
     topic_statuses:
       solved:
         help: "هذا الموضوع فيه الحل"
diff --git a/config/locales/client.bs_BA.yml b/config/locales/client.bs_BA.yml
index 63410e2..179827b 100644
--- a/config/locales/client.bs_BA.yml
+++ b/config/locales/client.bs_BA.yml
@@ -7,6 +7,29 @@
 bs_BA:
   js:
+    notifications:
+      alt:
+        solved:
+          accepted_notification: "prihvaćeno"
     solved:
+      title: "Riješeno"
+      allow_accepted_answers: "Dopustite vlasniku teme i osoblju da označe odgovor kao rješenje"
+      accept_answer: "Odaberite ako ovaj odgovor rješava problem"
+      accepted_description: "Ovo je prihvaćeno rješenje za ovu temu"
+      has_no_accepted_answer: "Ova tema nema rešenje"
+      unaccept_answer: "Poništite odabir ako ovaj odgovor više ne rješava problem"
+      accepted_answer: "Rešenje"
+      solution: "Rešenje"
+      solution_summary:
+        one: "riješenje"
+        few: "riješenja"
+        other: "riješenja"
+      accepted_html: "{{icon}} Riješio<span class='by'> <a href data-user-card='{{username_lower}}'>{{username}}</a></span> u<a href='{{post_path}}' class='back'>odgovoru #{{post_number}}</a>"
+      accepted_notification: "<p><span>{{username}}</span>{{description}}</p>"
         all: "sve"
+        solved: "riješeno"
+        unsolved: "nije riješeno"
+    topic_statuses:
+      solved:
+        help: "Ova tema ima riješenje"
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index 167be75..e225088 100644
--- a/config/locales/client.ca.yml
+++ b/config/locales/client.ca.yml
@@ -15,6 +15,7 @@ ca:
       title: "Solucionat"
       allow_accepted_answers: "Permet que el propietari del tema i l'equip responsable marquin una resposta com a solució"
       accept_answer: "Seleccioneu aquesta resposta si resol el problema"
+      accepted_description: "Aquesta és la solució acceptada per a aquest tema."
       has_no_accepted_answer: "Aquest tema no té cap solució"
       unaccept_answer: "Desseleccioneu aquesta resposta si ja no resol el problema"
       accepted_answer: "Solució"
diff --git a/config/locales/client.da.yml b/config/locales/client.da.yml
index 11ab310..72726b0 100644
--- a/config/locales/client.da.yml
+++ b/config/locales/client.da.yml
@@ -7,6 +7,10 @@
 da:
   js:
+    notifications:
+      alt:
+        solved:
+          accepted_notification: "accepteret"
     solved:
       allow_accepted_answers: "Tillad ejer af emne og stab at markere svar som en løsning"
       accepted_answer: "Løsning"
diff --git a/config/locales/client.de.yml b/config/locales/client.de.yml
index f24addd..77be9db 100644
--- a/config/locales/client.de.yml
+++ b/config/locales/client.de.yml
@@ -15,6 +15,7 @@ de:
       title: "Gelöst"
       allow_accepted_answers: "Erlaube dem Ersteller des Themas und Mitarbeitern eine Antwort als Lösung zu markieren"
       accept_answer: "Auswählen, wenn diese Antwort das Problem löst"
+      accepted_description: "Dies ist die für dieses Thema akzeptierte Lösung"
       has_no_accepted_answer: "Dieses Thema hat keine Lösung"
       unaccept_answer: "Abwählen, wenn diese Antwort das Problem nicht mehr löst"
       accepted_answer: "Lösung"
diff --git a/config/locales/client.es.yml b/config/locales/client.es.yml
index 2f7a7f8..a1f12ec 100644
--- a/config/locales/client.es.yml
+++ b/config/locales/client.es.yml
@@ -13,8 +13,9 @@ es:
           accepted_notification: "aceptado"
     solved:
       title: "Solucionado"
-      allow_accepted_answers: "Permitir que el autor del tema y el staff marquen una respuesta como solución"
-      accept_answer: "Seleccionar si esta respuesta soluciona el problema"
+      allow_accepted_answers: "Permitir al propietario del tema y al staff marcar una respuesta como la solución"
+      accept_answer: "Seleccionar si esta respuesta resuelve el problema"
+      accepted_description: "Esta es la solución aceptada para este tema"
       has_no_accepted_answer: "Este tema no tiene una solución"
       unaccept_answer: "Deseleccionar si esta respuesta ya no resuelve el problema"
       accepted_answer: "Solución"
@@ -22,10 +23,10 @@ es:
       solution_summary:
         one: "solución"
         other: "soluciones"
-      accepted_html: "{{icon}} Solucionado <span class='by'>por <a href data-user-card='{{username_lower}}'>{{username}}</a></span> en el <a href='{{post_path}}' class='back'>post #{{post_number}}</a>"
+      accepted_html: "{{icon}} Solucionado <span class='by'>por <a href data-user-card='{{username_lower}}'>{{username}}</a></span> en la <a href='{{post_path}}' class='back'>publicación #{{post_number}}</a>"
       accepted_notification: "<p><span>{{username}}</span> {{description}}</p>"
-        all: "todas"
+        all: "todos"
         solved: "solucionado"
         unsolved: "sin solución"
     topic_statuses:
diff --git a/config/locales/client.fi.yml b/config/locales/client.fi.yml
index ac64154..5fd768d 100644
--- a/config/locales/client.fi.yml
+++ b/config/locales/client.fi.yml
@@ -10,13 +10,14 @@ fi:
     notifications:
       alt:
         solved:
-          accepted_notification: "hyväksyi"
+          accepted_notification: "hyväksytty"
     solved:
-      title: "Ratkaisemat"
-      allow_accepted_answers: "Salli aiheen omistajan ja henkilökunnan merkitä viesti ratkaisuksi"
-      accept_answer: "Valitse, tämä vastaus ratkaisee ongelman"
+      title: "Ratkaistu"
+      allow_accepted_answers: "Salli ketjun omistajan ja henkilökunnan merkitä viesti ratkaisuksi"
+      accept_answer: "Valitse, jos tämä vastaus ratkaisee ongelman"
+      accepted_description: "Tämä on aiheelle hyväksytty ratkaisu"
       has_no_accepted_answer: "Tähän aiheeseen ei ole ratkaisua"
-      unaccept_answer: "Kumoa valinta, tämä vastaus ei enää ratkaise ongelmaa"
+      unaccept_answer: "Kumoa valinta, jos tämä vastaus ei enää ratkaise ongelmaa"
       accepted_answer: "Ratkaisu"
       solution: "Ratkaisu"
       solution_summary:
@@ -26,6 +27,8 @@ fi:
         all: "kaikki"
+        solved: "ratkaistu"
+        unsolved: "ratkaisematon"
     topic_statuses:
       solved:
         help: "Tämä aihe on ratkaistu"
diff --git a/config/locales/client.fr.yml b/config/locales/client.fr.yml
index dfffdf8..f416ce8 100644
--- a/config/locales/client.fr.yml
+++ b/config/locales/client.fr.yml
@@ -15,6 +15,7 @@ fr:
       title: "Solutions"
       allow_accepted_answers: "Autoriser l'auteur du sujet et les responsables à marquer une réponse comme solution"
       accept_answer: "Sélectionner si cette réponse résout le problème"
+      accepted_description: "C'est la solution acceptée à ce sujet"
       has_no_accepted_answer: "Ce sujet n'a pas de solution"
       unaccept_answer: "Désélectionner si cette réponse ne résout plus le problème"
       accepted_answer: "Solution"
diff --git a/config/locales/client.he.yml b/config/locales/client.he.yml
index e37cda6..c0dbc46 100644
--- a/config/locales/client.he.yml
+++ b/config/locales/client.he.yml
@@ -13,8 +13,9 @@ he:
           accepted_notification: "התקבל"
     solved:
       title: "נפתר"
GitHub sha: 17912bdd
