Use HEAD instead of @ shortcut for git in launcher (#428)
The abbreviation @ for HEAD was added in git 1.8.5. The launcher claims to be compatible with git version 1.8.0 but the use of this abbreviation breaks this compatibility. This change is needed to support RHEL 7.6 which has only git 1.8.3.1.
diff --git a/launcher b/launcher
index 4e61592..39928d9 100755
--- a/launcher
+++ b/launcher
@@ -760,9 +760,9 @@ case "$command" in
         git remote update
-        LOCAL=$(git rev-parse @)
+        LOCAL=$(git rev-parse HEAD)
         REMOTE=$(git rev-parse @{u})
-        BASE=$(git merge-base @ @{u})
+        BASE=$(git merge-base HEAD @{u})
         if [ $LOCAL = $REMOTE ]; then
           echo "Launcher is up-to-date"
GitHub sha: 755ab5ac
