UX: Allow saving with cmd+s/ctrl+s with Ace editor (PR #12674)
When editing the files for a theme in the admin dashboard, typing “cmd+s” (a common key-binding to save in most text editors) used to engage the browser’s default “save page” dialogue.
This commit adds a key-binding to the ace editor that saves the file.
Now, the “cmd+s” (and “ctrl+s” for windows) key-binding does the same action as the save button.
Note: I didn’t write a test for this because I’m not sure where the JS tests are located. I can write a test if needed as long as someone points me in the right direction.
GitHub
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
Awesome! Have you tested how this will affect ace-editor instances other than admin-theme-editor?
Off the top of my head, I think the data-explorer plugin uses ace-editor. Possibly some other places in core as well.
Maybe this should be something like
if(this.attrs.save){
  this.attrs.save()
So that it doesn’t throw an exception if the save attribute isn’t passed?
This was my first thought and it does prevent an error from showing up if the parent component/controller doesn’t have a ‘save’ action.
However, I’m thinking of putting the entire command declaration within that conditional like this –
if (this.attrs.save) {
  editor.commands.addCommand({
    exec: () => {
      this.attrs.save();
    bindKey: { mac: "cmd-s", win: "ctrl-s" },
That way, if the parent doesn’t define a save() action, the browser default save-page dialogue still pops up.
Good thinking @davidtaylorhq, the ace editor is also used in the email style editor and the badge_sql editor. I’m working on a fix for this and trying to identify the cause of the backend error that failed the CI check.
Thanks!!
I think we might have just been unlucky there. I restarted the tests and it seems fine now :grinning_face_with_smiling_eyes:
Ah okay, great!
I just tested that new code with and without a save attribute. When it’s included, the key-binding calls whatever save function was passed as an attribute. And when it’s not included, it doesn’t register the command and the browser default is run.
I just pushed the latest edits which address this (and also add the keybinding to the email-style-editor).
Do you want me to write a test for this? Or do you think it’s straightforward enough?
The title of this pull request changed from “UX: Allow saving with cmd+s/ctrl+s on admin/customize/theme/editor” to "UX: Allow saving with cmd+s/ctrl+s with Ace editor
Looks great, sorry for the delay here @graydenshand. Merging now :slight_smile:
