UX: Better composer hyperlink modal (PR #8160)
This brings the hyperlink modal in line with all other modals (upload, date, etc.) by placing the fixed modal element outside of the composer.
Before:
After:
GitHub
You’ve signed the CLA, pmusaraj. Thank you! This pull request is ready for review.
Does it have to be a computed property if the value is static?
Good spot, no, it doesn’t need to be computed at all.
ESLint error, computed is no longer used: Travis CI - Test and Deploy Your Code with Confidence
I support this cleanup, feel free to merge!
@pmusaraj It seems it’s no longer possible to submit the form by pressing enter/return. Could this PR be the cause?
Yes, it’s possible. I think our modals in general do not submit on return, I think we should fix that globally.
UX: Trigger primary action in modals using Enter should fix your issue @CvX.
