UX: Better emoji escaping for topic title (#7218)
  • FIX: Fixed failing discourse-prometheus-alert-receiver plugin specs
diff --git a/app/assets/javascripts/pretty-text/emoji.js.es6 b/app/assets/javascripts/pretty-text/emoji.js.es6
index 5b48a64..0e42452 100644
--- a/app/assets/javascripts/pretty-text/emoji.js.es6
+++ b/app/assets/javascripts/pretty-text/emoji.js.es6
@@ -3,7 +3,8 @@ import {
   aliases,
   searchAliases,
   translations,
-  tonableEmojis
+  tonableEmojis,
+  replacements
 } from "pretty-text/emoji/data";
 import { IMAGE_VERSION } from "pretty-text/emoji/version";
@@ -34,24 +35,43 @@ export function performEmojiUnescape(string, opts) {
     return;
-  // this can be further improved by supporting matches of emoticons that don't begin with a colon
-  if (string.indexOf(":") >= 0) {
-    return string.replace(/\B:[^\s:]+(?::t\d)?:?\B/g, m => {
-      const isEmoticon = !!translations[m];
-      const emojiVal = isEmoticon ? translations[m] : m.slice(1, m.length - 1);
-      const hasEndingColon = m.lastIndexOf(":") === m.length - 1;
-      const url = buildEmojiUrl(emojiVal, opts);
-      const classes = isCustomEmoji(emojiVal, opts)
-        ? "emoji emoji-custom"
-        : "emoji";
-      return url && (isEmoticon || hasEndingColon)
-        ? `<img src='${url}' ${
-            opts.skipTitle ? "" : `title='${emojiVal}'`
-          } alt='${emojiVal}' class='${classes}'>`
-        : m;
+  return string.replace(/[\u1000-\uFFFF]+|\B:[^\s:]+(?::t\d)?:?\B/g, m => {
+    const isEmoticon = !!translations[m];
+    const isUnicodeEmoticon = !!replacements[m];
+    let emojiVal;
+    if (isEmoticon) {
+      emojiVal = translations[m];
+    } else if (isUnicodeEmoticon) {
+      emojiVal = replacements[m];
+    } else {
+      emojiVal = m.slice(1, m.length - 1);
+    const hasEndingColon = m.lastIndexOf(":") === m.length - 1;
+    const url = buildEmojiUrl(emojiVal, opts);
+    const classes = isCustomEmoji(emojiVal, opts)
+      ? "emoji emoji-custom"
+      : "emoji";
+    return url && (isEmoticon || hasEndingColon || isUnicodeEmoticon)
+      ? `<img src='${url}' ${
+          opts.skipTitle ? "" : `title='${emojiVal}'`
+        } alt='${emojiVal}' class='${classes}'>`
+      : m;
+  return string;
+export function performEmojiEscape(string) {
+    if (!!translations[m]) {
+      return ":" + translations[m] + ":";
+    } else if (!!replacements[m]) {
+      return ":" + replacements[m] + ":";
+    } else {
+      return m;
   return string;
diff --git a/app/assets/javascripts/pretty-text/emoji/data.js.es6.erb b/app/assets/javascripts/pretty-text/emoji/data.js.es6.erb
index 32a9b98..5825170 100644
--- a/app/assets/javascripts/pretty-text/emoji/data.js.es6.erb
+++ b/app/assets/javascripts/pretty-text/emoji/data.js.es6.erb
@@ -3,3 +3,4 @@ export const tonableEmojis = <%= Emoji.tonable_emojis.flatten.inspect %>;
 export const aliases = <%= Emoji.aliases.inspect.gsub("=>", ":") %>;
 export const searchAliases = <%= Emoji.search_aliases.inspect.gsub("=>", ":") %>;
 export const translations = <%= Emoji.translations.inspect.gsub("=>", ":") %>;
+export const replacements = <%= Emoji.unicode_replacements_json %>;
diff --git a/app/models/emoji.rb b/app/models/emoji.rb
index 495d56b..db3261a 100644
--- a/app/models/emoji.rb
+++ b/app/models/emoji.rb
@@ -157,13 +157,7 @@ class Emoji
   def self.unicode_unescape(string)
-    string.each_char.map do |c|
-      if str = unicode_replacements[c]
-        ":#{str}:"
-      else
-        c
-      end
-    end.join
+    PrettyText.escape_emoji(string)
   def self.gsub_emoji_to_unicode(str)
diff --git a/lib/pretty_text.rb b/lib/pretty_text.rb
index d4d8ce5..1943417 100644
--- a/lib/pretty_text.rb
+++ b/lib/pretty_text.rb
@@ -227,7 +227,7 @@ module PrettyText
   def self.unescape_emoji(title)
-    return title unless SiteSetting.enable_emoji?
+    return title unless SiteSetting.enable_emoji? && title
     set = SiteSetting.emoji_set.inspect
     custom = Emoji.custom.map { |e| [e.name, e.url] }.to_h.to_json
@@ -239,6 +239,16 @@ module PrettyText
+  def self.escape_emoji(title)
+    return unless title
+    protect do
+      v8.eval(<<~JS)
+        __performEmojiEscape(#{title.inspect});
+      JS
+    end
+  end
   def self.cook(text, opts = {})
     options = opts.dup
diff --git a/lib/pretty_text/shims.js b/lib/pretty_text/shims.js
index 649c3e4..929dafd 100644
--- a/lib/pretty_text/shims.js
+++ b/lib/pretty_text/shims.js
@@ -1,6 +1,7 @@
 __PrettyText = require("pretty-text/pretty-text").default;
 __buildOptions = require("pretty-text/pretty-text").buildOptions;
 __performEmojiUnescape = require("pretty-text/emoji").performEmojiUnescape;
+__performEmojiEscape = require("pretty-text/emoji").performEmojiEscape;
 __utils = require("discourse/lib/utilities");
diff --git a/spec/models/topic_spec.rb b/spec/models/topic_spec.rb
index c28ce6f..65a9be8 100644
--- a/spec/models/topic_spec.rb
+++ b/spec/models/topic_spec.rb
@@ -279,6 +279,7 @@ describe Topic do
     let(:topic_image) { build_topic_with_title("Topic with <img src='something'> image in its title") }
     let(:topic_script) { build_topic_with_title("Topic with <script>alert('title')</script> script in its title") }
     let(:topic_emoji) { build_topic_with_title("I 💖 candy alot") }
+    let(:topic_modifier_emoji) { build_topic_with_title("I 👨‍🌾 candy alot") }
     it "escapes script contents" do
       expect(topic_script.fancy_title).to eq("Topic with &lt;script&gt;alert(&lsquo;title&rsquo;)&lt;/script&gt; script in its title")
@@ -288,6 +289,10 @@ describe Topic do
       expect(topic_emoji.fancy_title).to eq("I :sparkling_heart: candy alot")
+    it "keeps combined emojis" do
+      expect(topic_modifier_emoji.fancy_title).to eq("I :man_farmer: candy alot")
+    end
     it "escapes bold contents" do
       expect(topic_bold.fancy_title).to eq("Topic with &lt;b&gt;bold&lt;/b&gt; text in its title")
diff --git a/test/javascripts/acceptance/topic-test.js.es6 b/test/javascripts/acceptance/topic-test.js.es6
index 73447b5..6ba79ef 100644
--- a/test/javascripts/acceptance/topic-test.js.es6
+++ b/test/javascripts/acceptance/topic-test.js.es6
@@ -184,6 +184,23 @@ QUnit.test("Updating the topic title with emojis", async assert => {
+QUnit.test("Updating the topic title with unicode emojis", async assert => {
+  await visit("/t/internationalization-localization/280");
+  await click("#topic-title .d-icon-pencil-alt");
+  await fillIn("#edit-title", "emojis title 👨‍🌾");
+  await click("#topic-title .submit-edit");
+  assert.equal(
+    find(".fancy-title")
+      .html()
+      .trim(),
+    `emojis title <img src="/images/emoji/emoji_one/man_farmer.png?v=${v}" title="man_farmer" alt="man_farmer" class="emoji">`,
+    "it displays the new title with escaped unicode emojis"
 acceptance("Topic featured links", {
   loggedIn: true,
   settings: {
GitHub sha: f7b156ff
