UX: Don't reload page after saving settings when editing category.
UX: Don’t reload page after saving settings when editing category.
diff --git a/app/assets/javascripts/discourse/controllers/edit-category.js.es6 b/app/assets/javascripts/discourse/controllers/edit-category.js.es6
index d474c9b..d2fa1ae 100644
--- a/app/assets/javascripts/discourse/controllers/edit-category.js.es6
+++ b/app/assets/javascripts/discourse/controllers/edit-category.js.es6
@@ -64,29 +64,33 @@ export default Ember.Controller.extend(ModalFunctionality, {
   actions: {
     saveCategory() {
-      const self = this,
-        model = this.get("model"),
-        parentCategory = this.site
-          .get("categories")
-          .findBy("id", parseInt(model.get("parent_category_id"), 10));
+      const model = this.get("model");
+      const parentCategory = this.site
+        .get("categories")
+        .findBy("id", parseInt(model.get("parent_category_id"), 10));
       this.set("saving", true);
       model.set("parentCategory", parentCategory);
-      this.get("model")
+      model
         .save()
-        .then(function(result) {
-          self.set("saving", false);
-          self.send("closeModal");
+        .then(result => {
+          this.set("saving", false);
           model.setProperties({
             slug: result.category.slug,
-          DiscourseURL.redirectTo("/c/" + Discourse.Category.slugFor(model));
+          if (this.get("selectedTab") !== "settings") {
+            this.send("closeModal");
+            DiscourseURL.redirectTo("/c/" + Discourse.Category.slugFor(model));
-        .catch(function(error) {
-          self.flash(extractError(error), "error");
+        .catch(error => {
+          this.flash(extractError(error), "error");
diff --git a/test/javascripts/acceptance/category-edit-test.js.es6 b/test/javascripts/acceptance/category-edit-test.js.es6
index 968fb58..18a7410 100644
--- a/test/javascripts/acceptance/category-edit-test.js.es6
+++ b/test/javascripts/acceptance/category-edit-test.js.es6
@@ -3,7 +3,17 @@ import { acceptance } from "helpers/qunit-helpers";
 acceptance("Category Edit", {
   loggedIn: true,
-  settings: { email_in: true }
+  settings: { email_in: true },
+  pretend(server, helper) {
+    server.post("/categories", () => {
+      return helper.response({
+        category: {
+          slug: "bug",
+          id: 999
 QUnit.test("Can open the category modal", async assert => {
@@ -18,21 +28,25 @@ QUnit.test("Can open the category modal", async assert => {
 QUnit.test("Editing the category", async assert => {
   await visit("/c/bug");
   await click(".edit-category");
-  await fillIn("#edit-text-color", "#ff0000");
-  await click(".edit-category-topic-template");
-  await fillIn(".d-editor-input", "this is the new topic template");
-  await click(".edit-category-settings");
+  await click(".edit-category-settings a");
   const searchPriorityChooser = selectKit("#category-search-priority");
   await searchPriorityChooser.expand();
   await searchPriorityChooser.selectRowByValue(1);
+  await click("#save-category");
+  assert.ok(visible(".d-modal"), "it does not close the modal");
+  await click(".edit-category-general a");
+  await fillIn("#edit-text-color", "#ff0000");
+  await click(".edit-category-topic-template a");
+  await fillIn(".d-editor-input", "this is the new topic template");
   assert.ok(!visible(".d-modal"), "it closes the modal");
   assert.equal(
     DiscourseURL.redirectedTo,
     "/c/bug",
GitHub sha: dd142eec
hmmm dosn’t this cause issues if you reorder the category? Then it will not be in the right position in the composer until you do a full reload?
Is the reordering of category done in the edit category modal?
I think it is still there if fixed category positions is enabled. Plus you could move it so it has a different parent category and stuff will get very strange. I am pretty sure the reload was there to avoid all sorts of strange stuff.
Hmm I’ll just revert it for now. It was super strange that setting a simple thing requires a full reload. At some point, we should remove this hack.
Yeah I know if feels odd, but there is a lot of strange that can happen after you fuss with a category.
Topic templates can change, it can go from “secure” to “non secure”, colors can change, position can change, default sort order
I agree that it would be nice if we could sync up all the magic, but the shotgun approach is kind of ok here cause editing categories is so rare.
Revert "UX: Don't reload page after saving settings when editing category."
