UX: Improve error handling for common OmniAuth exceptions (#7991)
This displays more useful messages for the most common issues we see:
  • CSRF (when the user switches browser)
  • Invalid IAT (when the server clock is wrong)
  • OAuth::Unauthorized for OAuth1 providers, when the credentials are incorrect
This commit also stops earlier for disabled authenticators. Now we stop at the request phase, rather than the callback phase.
diff --git a/app/controllers/users/omniauth_callbacks_controller.rb b/app/controllers/users/omniauth_callbacks_controller.rb
index e9ed2d0..fb3578b 100644
--- a/app/controllers/users/omniauth_callbacks_controller.rb
+++ b/app/controllers/users/omniauth_callbacks_controller.rb
@@ -91,7 +91,8 @@ class Users::OmniauthCallbacksController < ApplicationController
   def failure
-    flash[:error] = I18n.t("login.omniauth_error")
+    error_key = params[:message].to_s.gsub(/[^\w-]/, "") || "generic"
+    flash[:error] = I18n.t("login.omniauth_error.#{error_key}", default: I18n.t("login.omniauth_error.generic"))
     render 'failure'
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 5c4d884..a3c13c2 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -2224,7 +2224,11 @@ en:
     errors: "%{errors}"
     not_available: "Not available. Try %{suggestion}?"
     something_already_taken: "Something went wrong, perhaps the username or email is already registered. Try the forgot password link."
-    omniauth_error: "Sorry, there was an error authorizing your account. Perhaps you did not approve authorization?"
+    omniauth_error:
+      generic: "Sorry, there was an error authorizing your account. Please try again."
+      csrf_detected: "Authorization timed out, or you have switched browsers. Please try again."
+      request_error: "An error occured when starting authorization. Please try again."
+      invalid_iat: "Unable to verify authorization token due to server clock differences. Please try again."
     omniauth_error_unknown: "Something went wrong processing your log in, please try again."
     omniauth_confirm_title: "Log in using %{provider}"
     omniauth_confirm_button: "Continue"
diff --git a/lib/csrf_token_verifier.rb b/lib/csrf_token_verifier.rb
index 1c18424..875e65e 100644
--- a/lib/csrf_token_verifier.rb
+++ b/lib/csrf_token_verifier.rb
@@ -2,6 +2,8 @@
 # Provides a way to check a CSRF token outside of a controller
 class CSRFTokenVerifier
+  class InvalidCSRFToken < StandardError; end
   include ActiveSupport::Configurable
   include ActionController::RequestForgeryProtection
@@ -17,7 +19,7 @@ class CSRFTokenVerifier
     @request = ActionDispatch::Request.new(env.dup)
     unless verified_request?
-      raise ActionController::InvalidAuthenticityToken
+      raise InvalidCSRFToken
diff --git a/lib/middleware/omniauth_bypass_middleware.rb b/lib/middleware/omniauth_bypass_middleware.rb
index 8f4fdf2..c40c892 100644
--- a/lib/middleware/omniauth_bypass_middleware.rb
+++ b/lib/middleware/omniauth_bypass_middleware.rb
@@ -5,6 +5,7 @@ require "csrf_token_verifier"
 # omniauth loves spending lots cycles in its magic middleware stack
 # this middleware bypasses omniauth middleware and only hits it when needed
 class Middleware::OmniauthBypassMiddleware
+  class AuthenticatorDisabled < StandardError; end
   def initialize(app, options = {})
     @app = app
@@ -24,6 +25,11 @@ class Middleware::OmniauthBypassMiddleware
       # Check for CSRF token
       CSRFTokenVerifier.new.call(env)
+      # Check whether the authenticator is enabled
+      if !Discourse.enabled_authenticators.any? { |a| a.name == env['omniauth.strategy'].name }
+        raise AuthenticatorDisabled
+      end
       # If the user is trying to reconnect to an existing account, store in session
       request = ActionDispatch::Request.new(env)
       request.session[:auth_reconnect] = !!request.params["reconnect"]
@@ -32,7 +38,27 @@ class Middleware::OmniauthBypassMiddleware
   def call(env)
     if env["PATH_INFO"].start_with?("/auth")
-      @omniauth.call(env)
+      begin
+        @omniauth.call(env)
+      rescue AuthenticatorDisabled => e
+        #  Authenticator is disabled, pretend it doesn't exist and pass request to app
+        @app.call(env)
+      rescue OAuth::Unauthorized => e
+        # OAuth1 (i.e. Twitter) makes a web request during the setup phase
+        # If it fails, Omniauth does not handle the error. Handle it here
+        env["omniauth.error.type"] ||= "request_error"
+        Rails.logger.error "Authentication failure! request_error: #{e.class}, #{e.message}"
+        OmniAuth::FailureEndpoint.call(env)
+      rescue JWT::InvalidIatError => e
+        # Happens for openid-connect (including google) providers, when the server clock is wrong
+        env["omniauth.error.type"] ||= "invalid_iat"
+        Rails.logger.error "Authentication failure! invalid_iat: #{e.class}, #{e.message}"
+      rescue CSRFTokenVerifier::InvalidCSRFToken => e
+        # Happens when CSRF token is missing from request
+        env["omniauth.error.type"] ||= "csrf_detected"
+      end
     else
       @app.call(env)
diff --git a/spec/requests/omniauth_callbacks_controller_spec.rb b/spec/requests/omniauth_callbacks_controller_spec.rb
index 2f4df1b..63850f6 100644
--- a/spec/requests/omniauth_callbacks_controller_spec.rb
+++ b/spec/requests/omniauth_callbacks_controller_spec.rb
@@ -87,7 +87,7 @@ RSpec.describe Users::OmniauthCallbacksController do
     it "should display the failure message if needed" do
       get "/auth/failure"
       expect(response.status).to eq(200)
-      expect(response.body).to include(I18n.t("login.omniauth_error"))
+      expect(response.body).to include(I18n.t("login.omniauth_error.generic"))
     describe "request" do
@@ -98,6 +98,28 @@ RSpec.describe Users::OmniauthCallbacksController do
         expect(response.status).to eq(403)
+      it "should error for disabled authenticators" do
+        SiteSetting.enable_google_oauth2_logins = false
+        post "/auth/google_oauth2"
+        expect(response.status).to eq(404)
+        get "/auth/google_oauth2"
+        expect(response.status).to eq(403)
+      end
+      it "should handle common errors" do
+        OmniAuth::Strategies::GoogleOauth2.any_instance.stubs(:mock_request_call).raises(
+          OAuth::Unauthorized.new(mock().tap { |m| m.stubs(:code).returns(403); m.stubs(:message).returns("Message") })
+        expect(response.status).to eq(302)
+        expect(response.location).to include("/auth/failure?message=request_error")
+        OmniAuth::Strategies::GoogleOauth2.any_instance.stubs(:mock_request_call).raises(JWT::InvalidIatError.new)
+        expect(response.location).to include("/auth/failure?message=invalid_iat")
+      end
       it "should only start auth with a POST request" do
@@ -111,10 +133,12 @@ RSpec.describe Users::OmniauthCallbacksController do
         it "should be CSRF protected" do
-          expect(response.status).to eq(422)
+          expect(response.location).to include("/auth/failure?message=csrf_detected")
           post "/auth/google_oauth2", params: { authenticity_token: "faketoken" }
           get "/session/csrf.json"
           token = JSON.parse(response.body)["csrf"]
diff --git a/spec/views/omniauth_callbacks/failure.html.erb_spec.rb b/spec/views/omniauth_callbacks/failure.html.erb_spec.rb
index a96dc16..78592b2 100644
--- a/spec/views/omniauth_callbacks/failure.html.erb_spec.rb
+++ b/spec/views/omniauth_callbacks/failure.html.erb_spec.rb
@@ -8,7 +8,7 @@ describe "users/omniauth_callbacks/failure.html.erb" do
     flash[:error] = I18n.t("login.omniauth_error", strategy: 'test')
       render
-      expect(rendered.match(I18n.t("login.omniauth_error", strategy: 'test'))).not_to eq(nil)
GitHub sha: 750802bf
Hello. Could you improve it even better? :wink: I’m just struggling with “Authorization timed out, or you have switched browsers. Please try again.”, and don’t have an idea where it comes from and how to prevent it.
