UX: Improve global notice description
Add “non-dismissible” to the site setting description for global notice per Global Notice | What's the use case? - support - Discourse Meta
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index c81a52f..eb74ea8 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -1817,7 +1817,7 @@ en:
     permalink_normalizations: "Apply the following regex before matching permalinks, for example: /(topic.*)\\?.*/\\1 will strip query strings from topic routes. Format is regex+string use \\1 etc. to access captures"
-    global_notice: "Display an URGENT, EMERGENCY global banner notice to all visitors, change to blank to hide it (HTML allowed)."
+    global_notice: "Display an URGENT, EMERGENCY, non-dismissible global banner notice to all visitors, change to blank to hide it (HTML allowed)."
     disable_edit_notifications: "Disables edit notifications by the system user when 'download_remote_images_to_local' is active."
GitHub sha: 1bf3e465
