UX: Improve Onebox code blocks with numbered lines (PR #11320)
Changes:
  • numbers column now fits the content
  • reduced the contrast of the border
  • made the numbers color use our css vars (i.e. fixed the contrast on the dark theme)
  • numbers are aligned with the code
  • the text selection doesn’t is no longer visible over the numbers
Note: uses display: table :eyes: Should I change it to use grid instead? (probably)
before/after light-before light-after dark-before dark-after
GitHub
This looks very nice!
oh yikes, didn’t realize how ugly that before was until seeing the after :clap:
Looks great!
Is the lack of indentation in the # Backup finalizer... line a regression?
It is… :sob:
Whitespace is collapsed, regardless of whitespace: pre, between the beginning of a display: table-row element and a first non-text node, i.e. an actual element. That disqualifies the display: table/table-row/table-cell technique. :slightly_frowning_face:
Not much luck with grid either. Since pseudo-elements (::before) are nested inside li it means that they can’t be a separate grid column.
Looks like changing the html is unavoidable… I’ll try to do it in a least compatibility-breaking way.
Totally support this change, but I think it makes sense to open a new PR with the new HTML to support it.
This has been in the oven for a bit too long.
