UX: Improve quick search suggestions (#13813)
diff --git a/app/assets/javascripts/discourse/app/lib/plugin-api.js b/app/assets/javascripts/discourse/app/lib/plugin-api.js
index cbf157d..5ffbaff 100644
--- a/app/assets/javascripts/discourse/app/lib/plugin-api.js
+++ b/app/assets/javascripts/discourse/app/lib/plugin-api.js
@@ -73,10 +73,10 @@ import { replaceFormatter } from "discourse/lib/utilities";
 import { replaceTagRenderer } from "discourse/lib/render-tag";
 import { setNewCategoryDefaultColors } from "discourse/routes/new-category";
 import { addSearchResultsCallback } from "discourse/lib/search";
-import { addInSearchShortcut } from "discourse/widgets/search-menu-results";
+import { addSearchSuggestion } from "discourse/widgets/search-menu-results";
 // If you add any methods to the API ensure you bump up this number
-const PLUGIN_API_VERSION = "0.11.6";
+const PLUGIN_API_VERSION = "0.11.7";
 class PluginApi {
   constructor(version, container) {
@@ -1298,15 +1298,15 @@ class PluginApi {
-   * Add a in: shortcut to search menu panel.
+   * Add a suggestion shortcut to search menu panel.
-   * addInSearchShortcut("in:assigned");
+   * addSearchSuggestion("in:assigned");
-  addInSearchShortcut(value) {
-    addInSearchShortcut(value);
+  addSearchSuggestion(value) {
+    addSearchSuggestion(value);
diff --git a/app/assets/javascripts/discourse/app/widgets/search-menu-results.js b/app/assets/javascripts/discourse/app/widgets/search-menu-results.js
index 5ef9d05..3245773 100644
--- a/app/assets/javascripts/discourse/app/widgets/search-menu-results.js
+++ b/app/assets/javascripts/discourse/app/widgets/search-menu-results.js
@@ -10,30 +10,22 @@ import highlightSearch from "discourse/lib/highlight-search";
 import { iconNode } from "discourse-common/lib/icon-library";
 import renderTag from "discourse/lib/render-tag";
-const inSearchShortcuts = [
+const suggestionShortcuts = [
   "in:title",
-  "in:personal",
-  "in:seen",
-  "in:likes",
-  "in:bookmarks",
-  "in:created",
-const statusSearchShortcuts = [
+  "in:pinned",
   "status:open",
   "status:closed",
   "status:public",
   "status:noreplies",
-const orderSearchShortcuts = [
   "order:latest",
   "order:views",
   "order:likes",
   "order:latest_topic",
-export function addInSearchShortcut(value) {
-  if (inSearchShortcuts.indexOf(value) === -1) {
-    inSearchShortcuts.push(value);
+export function addSearchSuggestion(value) {
+  if (suggestionShortcuts.indexOf(value) === -1) {
+    suggestionShortcuts.push(value);
@@ -360,8 +352,19 @@ createWidget("search-menu-assistant", {
   tagName: "ul.search-menu-assistant",
   html(attrs) {
+    if (this.currentUser) {
+      addSearchSuggestion("in:likes");
+      addSearchSuggestion("in:bookmarks");
+      addSearchSuggestion("in:mine");
+      addSearchSuggestion("in:personal");
+      addSearchSuggestion("in:seen");
+      addSearchSuggestion("in:tracking");
+      addSearchSuggestion("in:unseen");
+      addSearchSuggestion("in:watching");
     if (this.siteSettings.tagging_enabled) {
-      addInSearchShortcut("in:tagged");
+      addSearchSuggestion("in:tagged");
+      addSearchSuggestion("in:untagged");
     const content = [];
@@ -370,7 +373,7 @@ createWidget("search-menu-assistant", {
     switch (suggestionKeyword) {
       case "#":
-        attrs.results.map((category) => {
+        attrs.results.forEach((category) => {
           const slug = prefix
             ? `${prefix} #${category.slug} `
             : `#${category.slug} `;
@@ -385,7 +388,7 @@ createWidget("search-menu-assistant", {
         break;
       case "@":
-        attrs.results.map((user) => {
+        attrs.results.forEach((user) => {
           const slug = prefix
             ? `${prefix} @${user.username} `
             : `@${user.username} `;
@@ -399,27 +402,17 @@ createWidget("search-menu-assistant", {
         break;
-      case "in:":
-        inSearchShortcuts.map((item) => {
-          const slug = prefix ? `${prefix} ${item} ` : item;
-          content.push(this.attach("search-menu-assistant-item", { slug }));
-        break;
-      case "status:":
-        statusSearchShortcuts.map((item) => {
-        break;
-      case "order:":
-        orderSearchShortcuts.map((item) => {
+      default:
+        suggestionShortcuts.forEach((item) => {
+          if (item.includes(suggestionKeyword)) {
+            const slug = prefix ? `${prefix} ${item} ` : `${item} `;
+            content.push(this.attach("search-menu-assistant-item", { slug }));
         break;
-    return content;
+    return content.filter((c, i) => i <= 8);
diff --git a/app/assets/javascripts/discourse/app/widgets/search-menu.js b/app/assets/javascripts/discourse/app/widgets/search-menu.js
index d91628c..f34668e 100644
--- a/app/assets/javascripts/discourse/app/widgets/search-menu.js
+++ b/app/assets/javascripts/discourse/app/widgets/search-menu.js
@@ -11,9 +11,9 @@ import userSearch from "discourse/lib/user-search";
 const CATEGORY_SLUG_REGEXP = /(\#[a-zA-Z0-9\-:]*)$/gi;
 const USERNAME_REGEXP = /(\@[a-zA-Z0-9\-\_]*)$/gi;
+const SUGGESTIONS_REGEXP = /(in:|status:|order:|:)([a-zA-Z]*)$/gi;
 const searchData = {};
-const suggestionTriggers = ["in:", "status:", "order:"];
 export function initSearchData() {
   searchData.loading = false;
@@ -53,47 +53,42 @@ const SearchHelper = {
       searchData.results = [];
-      if (typeof matchSuggestions === "string") {
-        searchData.suggestionKeyword = matchSuggestions;
+      if (matchSuggestions.type === "category") {
+        const categorySearchTerm = matchSuggestions.categoriesMatch[0].replace(
+        searchData.suggestionResults = Category.search(categorySearchTerm);
+        searchData.suggestionKeyword = "#";
         widget.scheduleRerender();
-        return;
-      } else {
-        if (matchSuggestions.type === "category") {
-          const categorySearchTerm = matchSuggestions.categoriesMatch[0].replace(
-          searchData.suggestionResults = Category.search(categorySearchTerm);
-          searchData.suggestionKeyword = "#";
-          widget.scheduleRerender();
-          return;
+      } else if (matchSuggestions.type === "username") {
+        const userSearchTerm = matchSuggestions.usernamesMatch[0].replace(
+        const opts = { includeGroups: true, limit: 6 };
+        if (userSearchTerm.length > 0) {
+          opts.term = userSearchTerm;
+        } else {
+          opts.lastSeenUsers = true;
-        if (matchSuggestions.type === "username") {
-          const userSearchTerm = matchSuggestions.usernamesMatch[0].replace(
-          const opts = { includeGroups: true, limit: 6 };
-          if (userSearchTerm.length > 0) {
-            opts.term = userSearchTerm;
+        userSearch(opts).then((result) => {
+          if (result?.users?.length > 0) {
+            searchData.suggestionResults = result.users;
+            searchData.suggestionKeyword = "@";
           } else {
-            opts.lastSeenUsers = true;
+            searchData.noResults = true;
+            searchData.suggestionKeyword = false;
-          userSearch(opts).then((result) => {
-            if (result?.users?.length > 0) {
-              searchData.suggestionResults = result.users;
-              searchData.suggestionKeyword = "@";
GitHub sha: 8a470e508e9a4134e1127d3c81b2fd53f06a1974
This commit appears in #13813 which was approved by eviltrout. It was merged by pmusaraj.
