UX: inform staff users that new users will be auto-approved on invite (#11062)
When must_approve_users is enabled then staff users assume that all users will have to be approved manually. But in case of invite we auto-approve users if they are invited by users. This commit adds an info on the bottom of invite modal informing staff users that new users will be auto-approved as soon as they accept invite.
diff --git a/app/assets/javascripts/discourse/app/components/invite-link-panel.js b/app/assets/javascripts/discourse/app/components/invite-link-panel.js
index 793b742..27c2d53 100644
--- a/app/assets/javascripts/discourse/app/components/invite-link-panel.js
+++ b/app/assets/javascripts/discourse/app/components/invite-link-panel.js
@@ -1,7 +1,7 @@
 import I18n from "I18n";
 import Component from "@ember/component";
 import Group from "discourse/models/group";
-import { alias, readOnly } from "@ember/object/computed";
+import { and, readOnly } from "@ember/object/computed";
 import { action } from "@ember/object";
 import discourseComputed from "discourse-common/utils/decorators";
 import Invite from "discourse/models/invite";
@@ -10,13 +10,12 @@ export default Component.extend({
   inviteModel: readOnly("panel.model.inviteModel"),
   userInvitedShow: readOnly("panel.model.userInvitedShow"),
   isStaff: readOnly("currentUser.staff"),
+  isAdmin: readOnly("currentUser.admin"),
   maxRedemptionAllowed: 5,
   inviteExpiresAt: moment().add(1, "month").format("YYYY-MM-DD"),
   groupIds: null,
   allGroups: null,
-  isAdmin: alias("currentUser.admin"),
   init() {
     this._super(...arguments);
     this.setDefaultSelectedGroups();
@@ -52,6 +51,8 @@ export default Component.extend({
+  showApprovalMessage: and("isStaff", "siteSettings.must_approve_users"),
   reset() {
     this.setProperties({
diff --git a/app/assets/javascripts/discourse/app/components/invite-panel.js b/app/assets/javascripts/discourse/app/components/invite-panel.js
index 703195a..9b28918 100644
--- a/app/assets/javascripts/discourse/app/components/invite-panel.js
+++ b/app/assets/javascripts/discourse/app/components/invite-panel.js
@@ -2,7 +2,7 @@ import I18n from "I18n";
 import { isEmpty } from "@ember/utils";
 import EmberObject, { action } from "@ember/object";
-import { alias, and, equal } from "@ember/object/computed";
+import { alias, and, equal, readOnly } from "@ember/object/computed";
 import { emailValid } from "discourse/lib/utilities";
@@ -17,6 +17,8 @@ export default Component.extend({
   inviteModel: alias("panel.model.inviteModel"),
   userInvitedShow: alias("panel.model.userInvitedShow"),
+  isStaff: readOnly("currentUser.staff"),
   // If this isn't defined, it will proxy to the user topic on the preferences
   // page which is wrong.
@@ -26,8 +28,6 @@ export default Component.extend({
   inviteIcon: "envelope",
   invitingExistingUserToTopic: false,
   init() {
@@ -288,6 +288,8 @@ export default Component.extend({
       : "topic.invite_reply.username_placeholder";
   customMessagePlaceholder: i18n("invite.custom_message_placeholder"),
   // Reset the modal to allow a new user to be invited.
diff --git a/app/assets/javascripts/discourse/app/templates/components/invite-link-panel.hbs b/app/assets/javascripts/discourse/app/templates/components/invite-link-panel.hbs
index 270df19..17f2e30 100644
--- a/app/assets/javascripts/discourse/app/templates/components/invite-link-panel.hbs
+++ b/app/assets/javascripts/discourse/app/templates/components/invite-link-panel.hbs
@@ -41,6 +41,11 @@
     </div>
+    {{#if showApprovalMessage}}
+      <label class="instructions approval-notice">
+        {{i18n "invite.approval_not_required"}}
+      </label>
+    {{/if}}
   {{/if}}
 </div>
diff --git a/app/assets/javascripts/discourse/app/templates/components/invite-panel.hbs b/app/assets/javascripts/discourse/app/templates/components/invite-panel.hbs
index ea571e6..8a65564 100644
--- a/app/assets/javascripts/discourse/app/templates/components/invite-panel.hbs
+++ b/app/assets/javascripts/discourse/app/templates/components/invite-panel.hbs
@@ -76,6 +76,12 @@
       </div>
     {{/if}}
   {{/if}}
+    </label>
+  {{/if}}
 </div>
 <div class="footer">
diff --git a/app/assets/stylesheets/common/components/share-and-invite-modal.scss b/app/assets/stylesheets/common/components/share-and-invite-modal.scss
index 3a301fd..20fc011 100644
--- a/app/assets/stylesheets/common/components/share-and-invite-modal.scss
+++ b/app/assets/stylesheets/common/components/share-and-invite-modal.scss
@@ -94,6 +94,10 @@
       margin-bottom: 8px;
+    .instructions.approval-notice {
+      color: var(--secondary-medium);
     .email-or-username-input {
       width: 100%;
diff --git a/config/locales/client.en.yml b/config/locales/client.en.yml
index 6a44c0d..061fe1e 100644
--- a/config/locales/client.en.yml
+++ b/config/locales/client.en.yml
@@ -3484,6 +3484,7 @@ en:
     invite:
       custom_message: "Make your invite a little bit more personal by writing a <a href>custom message</a>."
       custom_message_placeholder: "Enter your custom message"
+      approval_not_required: "User will be auto-approved as soon as they will accept this invite."
       custom_message_template_forum: "Hey, you should join this forum!"
       custom_message_template_topic: "Hey, I thought you might enjoy this topic!"
GitHub sha: 8f7f5204
This commit appears in #11062 which was approved by eviltrout. It was merged by techAPJ.
