UX: shows a hint when there are more tags than displayed (#12649)
diff --git a/app/assets/javascripts/select-kit/addon/components/tag-drop.js b/app/assets/javascripts/select-kit/addon/components/tag-drop.js
index e28079a..16fb2ca 100644
--- a/app/assets/javascripts/select-kit/addon/components/tag-drop.js
+++ b/app/assets/javascripts/select-kit/addon/components/tag-drop.js
@@ -5,11 +5,14 @@ import DiscourseURL, { getCategoryAndTagUrl } from "discourse/lib/url";
import TagsMixin from "select-kit/mixins/tags";
import { computed } from "@ember/object";
import { makeArray } from "discourse-common/lib/helpers";
+import { MAIN_COLLECTION } from "select-kit/components/select-kit";
export const NO_TAG_ID = "no-tags";
export const ALL_TAGS_ID = "all-tags";
export const NONE_TAG_ID = "none";
+const MORE_TAGS_COLLECTION = "MORE_TAGS_COLLECTION";
export default ComboBoxComponent.extend(TagsMixin, {
pluginApiIdentifiers: ["tag-drop"],
classNameBindings: ["categoryStyle", "tagClass"],
@@ -19,6 +22,14 @@ export default ComboBoxComponent.extend(TagsMixin, {
categoryStyle: setting("category_style"),
maxTagSearchResults: setting("max_tag_search_results"),
sortTagsAlphabetically: setting("tags_sort_alphabetically"),
+ maxTagsInFilterList: setting("max_tags_in_filter_list"),
+ shouldShowMoreTags: computed(
+ "maxTagsInFilterList",
+ "topTags.[]",
+ function () {
+ return this.topTags.length > this.maxTagsInFilterList;
selectKitOptions: {
allowAny: false,
@@ -34,6 +45,26 @@ export default ComboBoxComponent.extend(TagsMixin, {
filterable: gte("content.length", 15),
+ init() {
+ this._super(...arguments);
+ this.insertAfterCollection(MAIN_COLLECTION, MORE_TAGS_COLLECTION);
+ modifyComponentForCollection(collection) {
+ if (collection === MORE_TAGS_COLLECTION) {
+ return "tag-drop/more-tags-collection";
+ modifyContentForCollection(collection) {
+ return {
+ shouldShowMoreTags: this.shouldShowMoreTags,
modifyNoSelection() {
if (this.noTagsSelected) {
return this.defaultItem(NO_TAG_ID, this.noTagsLabel);
@@ -90,18 +121,19 @@ export default ComboBoxComponent.extend(TagsMixin, {
"site.top_tags.[]",
function () {
if (this.currentCategory && this.site.category_top_tags) {
- return this.site.category_top_tags;
+ return this.site.category_top_tags || [];
- return this.site.top_tags;
+ return this.site.top_tags || [];
content: computed("topTags.[]", "shortcuts.[]", function () {
- if (this.sortTagsAlphabetically && this.topTags) {
- return this.shortcuts.concat(this.topTags.sort());
+ const topTags = this.topTags.slice(0, this.maxTagsInFilterList);
+ if (this.sortTagsAlphabetically && topTags) {
+ return this.shortcuts.concat(topTags.sort());
} else {
- return this.shortcuts.concat(makeArray(this.topTags));
+ return this.shortcuts.concat(makeArray(topTags));
diff --git a/app/assets/javascripts/select-kit/addon/components/tag-drop/more-tags-collection.js b/app/assets/javascripts/select-kit/addon/components/tag-drop/more-tags-collection.js
new file mode 100644
index 0000000..af08653
--- /dev/null
+++ b/app/assets/javascripts/select-kit/addon/components/tag-drop/more-tags-collection.js
@@ -0,0 +1,10 @@
+import Component from "@ember/component";
+import layout from "select-kit/templates/components/tag-drop/more-tags-collection";
+export default Component.extend({
+ tagName: "",
+ layout,
+ collection: null,
diff --git a/app/assets/javascripts/select-kit/addon/templates/components/tag-drop/more-tags-collection.hbs b/app/assets/javascripts/select-kit/addon/templates/components/tag-drop/more-tags-collection.hbs
index 0000000..fe381b4
--- /dev/null
+++ b/app/assets/javascripts/select-kit/addon/templates/components/tag-drop/more-tags-collection.hbs
@@ -0,0 +1,5 @@
+{{#if collection.content.shouldShowMoreTags}}
+ <div class="more-tags">
+ {{i18n "select_kit.components.tag_drop.filter_for_more"}}
+ </div>
+{{/if}}
diff --git a/app/assets/stylesheets/common/select-kit/tag-drop.scss b/app/assets/stylesheets/common/select-kit/tag-drop.scss
index 382c378..09d456c 100644
--- a/app/assets/stylesheets/common/select-kit/tag-drop.scss
+++ b/app/assets/stylesheets/common/select-kit/tag-drop.scss
@@ -10,6 +10,15 @@
font-weight: 700;
+ .more-tags {
+ display: flex;
+ box-sizing: border-box;
+ width: 100%;
+ padding: 0.5em 1em;
+ font-size: $font-down-1;
+ color: var(--primary-low-mid);
diff --git a/app/models/tag.rb b/app/models/tag.rb
index 5245843..78b30fb 100644
--- a/app/models/tag.rb
+++ b/app/models/tag.rb
@@ -95,7 +95,9 @@ class Tag < ActiveRecord::Base
def self.top_tags(limit_arg: nil, category: nil, guardian: nil)
- limit = limit_arg || SiteSetting.max_tags_in_filter_list
+ # we add 1 to max_tags_in_filter_list to efficiently know we have more tags
+ # than the limit. Frontend is responsible to enforce limit.
+ limit = limit_arg || (SiteSetting.max_tags_in_filter_list + 1)
scope_category_ids = (guardian || Guardian.new).allowed_category_ids
if category
diff --git a/config/locales/client.en.yml b/config/locales/client.en.yml
index c1e0274..9a30d8c 100644
--- a/config/locales/client.en.yml
+++ b/config/locales/client.en.yml
@@ -1919,6 +1919,8 @@ en:
one: "Selection must be at least %{count} character."
other: "Selection must be at least %{count} characters."
components:
+ tag_drop:
+ filter_for_more: Filter for more...
categories_admin_dropdown:
title: "Manage categories"
GitHub sha: 081ada09
