UX: Survey style enhancements (#2)
diff --git a/assets/javascripts/widgets/discourse-survey.js.es6 b/assets/javascripts/widgets/discourse-survey.js.es6
index bd32bd9..02ff5c2 100644
--- a/assets/javascripts/widgets/discourse-survey.js.es6
+++ b/assets/javascripts/widgets/discourse-survey.js.es6
@@ -8,7 +8,9 @@ import { popupAjaxError } from "discourse/lib/ajax-error";
 function fieldHtml(field) {
   const $node = $(`<span>${field.question}</span>`);
-  return new RawHtml({ html: `<span class="field-question">${$node.html()}</span>` });
+  return new RawHtml({
+    html: `<span class="field-question">${$node.html()}</span>`
 createWidget("discourse-survey-field", {
@@ -29,75 +31,81 @@ createWidget("discourse-survey-field", {
     if (field.response_type === 6) {
       // dropdown field
       contents.push(
-        h("div.field-dropdown",
+        h(
+          "div.field-dropdown",
           this.attach("discourse-survey-field-dropdown", {
             options: field.options,
             fieldId: attrs.field.digest
     } else if (hasOptions) {
       // radio & checkbox field
       contents.push(
-        h("div",
+        h(
+          "div",
           field.options.map(option => {
             return this.attach("discourse-survey-field-option", {
               option,
               fieldId: attrs.field.digest,
               isMultiple,
               response: attrs.response[attrs.field.digest]
     } else if (field.response_type === 2) {
       // number field
-      const values = Array.from(Array(10), (_, i) => i + 1)
+      const values = Array.from(Array(10), (_, i) => i + 1);
       contents.push(
-        h("div.field-number",
+        h(
+          "div.field-number",
           values.map(value => {
             return this.attach("discourse-survey-field-number", {
               value: value,
     } else if (field.response_type === 3) {
       // textarea field
       contents.push(
-        h("div.field-textarea",
+        h(
+          "div.field-textarea",
           this.attach("discourse-survey-field-textarea", {
     } else if (field.response_type === 4) {
       // star rating field
-      const values = Array.from(Array(6).keys())
+      const values = Array.from(Array(6).keys());
       contents.push(
-        h("div.field-star",
+        h(
+          "div.field-star",
           this.attach("discourse-survey-field-star", {
             postId: attrs.postId,
             values
     } else if (field.response_type === 5) {
       // thumbs up/down field
       contents.push(
-        h("div.field-thumbs",
+        h(
+          "div.field-thumbs",
           this.attach("discourse-survey-field-thumbs", {
     return contents;
@@ -133,7 +141,7 @@ createWidget("discourse-survey-field-option", {
     if (attrs.isMultiple) {
       contents.push(iconNode(chosen ? "far-check-square" : "far-square"));
     } else {
-      contents.push(iconNode(chosen ? "circle" : "far-circle"));
+      contents.push(iconNode(chosen ? "far-check-circle" : "far-circle"));
     contents.push(" ");
@@ -161,7 +169,10 @@ createWidget("discourse-survey-field-textarea", {
   keyUp(e) {
     // remove zero-width chars
     const value = e.target.value.replace(/[\u200B-\u200D\uFEFF]/, "");
-    this.sendWidgetAction("toggleValue", {value: value, fieldId: this.attrs.fieldId});
+    this.sendWidgetAction("toggleValue", {
+      value: value,
+      fieldId: this.attrs.fieldId
@@ -186,7 +197,10 @@ createWidget("discourse-survey-field-number", {
   click(e) {
     if ($(e.target).closest("a").length === 0) {
-      this.sendWidgetAction("toggleValue", {value: this.attrs.value, fieldId: this.attrs.fieldId});
+        value: this.attrs.value,
@@ -199,14 +213,21 @@ createWidget("discourse-survey-field-dropdown", {
     contents.push(new RawHtml({ html: `<option label=" "></option>` }));
     attrs.options.map(option => {
-      contents.push(new RawHtml({ html: `<option value="${option.digest}">${option.html}</option>` }));
+      contents.push(
+        new RawHtml({
+          html: `<option value="${option.digest}">${option.html}</option>`
     return contents;
   change(e) {
-    this.sendWidgetAction("toggleValue", {value: e.target.value, fieldId: this.attrs.fieldId});
+      value: e.target.value,
@@ -219,10 +240,24 @@ createWidget("discourse-survey-field-star", {
     attrs.values.forEach(value => {
       if (value > 0) {
-        contents.push(new RawHtml({ html: `<label class="star-rating-label" for="star-rating-${postId}-${value}">${iconHTML("star")}</label>` }));
-        contents.push(new RawHtml({ html: `<input id="star-rating-${postId}-${value}" name="star-rating-${postId}" class="star-rating-input" value="${value}" type="radio">` }));
+        contents.push(
+          new RawHtml({
+            html: `<label class="star-rating-label" for="star-rating-${postId}-${value}">${iconHTML(
+              "star"
+            )}</label>`
+        contents.push(
+          new RawHtml({
+            html: `<input id="star-rating-${postId}-${value}" name="star-rating-${postId}" class="star-rating-input" value="${value}" type="radio">`
       } else {
-        contents.push(new RawHtml({ html: `<input id="star-rating-${postId}-0" name="star-rating-${postId}" disabled checked class="star-rating-input" value="0" type="radio">` }));
+        contents.push(
+          new RawHtml({
+            html: `<input id="star-rating-${postId}-0" name="star-rating-${postId}" disabled checked class="star-rating-input" value="0" type="radio">`
@@ -231,7 +266,12 @@ createWidget("discourse-survey-field-star", {
   click(e) {
-      this.sendWidgetAction("toggleValue", {value: $(`input[name*='star-rating-${this.attrs.postId}']:checked`).val(), fieldId: this.attrs.fieldId});
+        value: $(
+          `input[name*='star-rating-${this.attrs.postId}']:checked`
+        ).val(),
@@ -244,19 +284,46 @@ createWidget("discourse-survey-field-thumbs", {
     const postId = attrs.postId;
     // thumbs up
-    contents.push(new RawHtml({ html: `<input id="thumbs-rating-up-${postId}" name="thumbs-rating-${postId}" class="thumbs-rating-input" value="+1" type="radio">` }));
-    contents.push(new RawHtml({ html: `<label class="thumbs-rating-label thumbs-up" for="thumbs-rating-up-${postId}">${iconHTML("thumbs-up", { class: "thumbs-icon" })}</label>` }));
+    contents.push(
+      new RawHtml({
+        html: `<input id="thumbs-rating-up-${postId}" name="thumbs-rating-${postId}" class="thumbs-rating-input" value="+1" type="radio">`
+    contents.push(
+      new RawHtml({
+        html: `<label class="thumbs-rating-label thumbs-up" for="thumbs-rating-up-${postId}">${iconHTML(
+          "thumbs-up",
+          { class: "thumbs-icon" }
+        )}</label>`
     // thumbs down
GitHub sha: 4da06a02
This commit appears in #2 which was merged by hnb-ku.
