UX: suspend forever time period messages (#13776)
When the Forever option is selected for suspending a user, the user is suspended for 1000 years. Without customizing the site’s text, this time period is displayed to the user in the suspension email that is sent to the user, and if the user attempts to log back into the site. Telling someone that they have been suspended for 1000 years seems likely to come across as a bad attempt at humour.
This PR special case messages when a user suspended or silenced forever.
diff --git a/app/controllers/session_controller.rb b/app/controllers/session_controller.rb
index ffd9381..5857416 100644
--- a/app/controllers/session_controller.rb
+++ b/app/controllers/session_controller.rb
@@ -589,13 +589,8 @@ class SessionController < ApplicationController
   def failed_to_login(user)
-    message = user.suspend_reason ? "login.suspended_with_reason" : "login.suspended"
-      error: I18n.t(message,
-        date: I18n.l(user.suspended_till, format: :date_only),
-        reason: Rack::Utils.escape_html(user.suspend_reason)
+      error: user.suspended_message,
       reason: 'suspended'
diff --git a/app/mailers/user_notifications.rb b/app/mailers/user_notifications.rb
index d5a20e0..8770330 100644
--- a/app/mailers/user_notifications.rb
+++ b/app/mailers/user_notifications.rb
@@ -153,13 +153,22 @@ class UserNotifications < ActionMailer::Base
     return unless user_history = opts[:user_history]
-    build_email(
-      user.email,
-      template: "user_notifications.account_silenced",
-      locale: user_locale(user),
-      reason: user_history.details,
-      silenced_till: I18n.l(user.silenced_till, format: :long)
+    if user.silenced_forever?
+      build_email(
+        user.email,
+        template: "user_notifications.account_silenced_forever",
+        locale: user_locale(user),
+        reason: user_history.details
+    else
+      build_email(
+        user.email,
+        template: "user_notifications.account_silenced",
+        reason: user_history.details,
+        silenced_till: I18n.l(user.silenced_till, format: :long)
+    end
   def account_suspended(user, opts = nil)
@@ -167,13 +176,22 @@ class UserNotifications < ActionMailer::Base
-    build_email(
-      user.email,
-      template: "user_notifications.account_suspended",
-      suspended_till: I18n.l(user.suspended_till, format: :long)
+    if user.suspended_forever?
+      build_email(
+        user.email,
+        template: "user_notifications.account_suspended_forever",
+    else
+      build_email(
+        user.email,
+        template: "user_notifications.account_suspended",
+        suspended_till: I18n.l(user.suspended_till, format: :long)
+    end
   def account_exists(user, opts = {})
diff --git a/app/models/user.rb b/app/models/user.rb
index da4dbed..4f80745 100644
--- a/app/models/user.rb
+++ b/app/models/user.rb
@@ -958,6 +958,10 @@ class User < ActiveRecord::Base
     silenced_record.try(:created_at) if silenced?
+  def silenced_forever?
+    silenced_till > 100.years.from_now
+  end
   def suspend_record
     UserHistory.for(self, :suspend_user).order('id DESC').first
@@ -974,6 +978,27 @@ class User < ActiveRecord::Base
     nil
+  def suspended_message
+    return nil unless suspended?
+    message = "login.suspended"
+    if suspend_reason
+      if suspended_forever?
+        message = "login.suspended_with_reason_forever"
+      else
+        message = "login.suspended_with_reason"
+      end
+    end
+    I18n.t(message,
+           date: I18n.l(suspended_till, format: :date_only),
+           reason: Rack::Utils.escape_html(suspend_reason))
+  end
+  def suspended_forever?
+    suspended_till > 100.years.from_now
+  end
   # Use this helper to determine if the user has a particular trust level.
   # Takes into account admin, etc.
   def has_trust_level?(level)
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 3b57d2a..d92c007 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -2515,6 +2515,7 @@ en:
     reset_not_allowed_from_ip_address: "You can't request a password reset from that IP address."
     suspended: "You can't log in until %{date}."
     suspended_with_reason: "Account suspended until %{date}: %{reason}"
+    suspended_with_reason_forever: "Account suspended: %{reason}"
     errors: "%{errors}"
     not_available: "Not available. Try %{suggestion}?"
     something_already_taken: "Something went wrong, perhaps the username or email is already registered. Try the forgot password link."
@@ -3703,6 +3704,14 @@ en:
         Reason - %{reason}
+    account_suspended_forever:
+      title: "Account Suspended"
+      subject_template: "[%{email_prefix}] Your account has been suspended"
+      text_body_template: |
+        You have been suspended from the forum.
+        Reason - %{reason}
     account_silenced:
       title: "Account Silenced"
       subject_template: "[%{email_prefix}] Your account has been silenced"
@@ -3711,6 +3720,14 @@ en:
         Reason - %{reason}
+    account_silenced_forever:
+      title: "Account Silenced"
+      subject_template: "[%{email_prefix}] Your account has been silenced"
+        You have been silenced from the forum.
     account_exists:
       title: "Account already exists"
       subject_template: "[%{email_prefix}] Account already exists"
diff --git a/lib/auth/result.rb b/lib/auth/result.rb
index 1b9c1d8..08a1220 100644
--- a/lib/auth/result.rb
+++ b/lib/auth/result.rb
@@ -111,8 +111,7 @@ class Auth::Result
     if user&.suspended?
       return {
         suspended: true,
-        suspended_message: I18n.t(user.suspend_reason ? "login.suspended_with_reason" : "login.suspended",
-                                   date: I18n.l(user.suspended_till, format: :date_only), reason: user.suspend_reason)
+        suspended_message: user.suspended_message
diff --git a/spec/requests/session_controller_spec.rb b/spec/requests/session_controller_spec.rb
index 6bf7b0e..74fce78 100644
--- a/spec/requests/session_controller_spec.rb
+++ b/spec/requests/session_controller_spec.rb
@@ -1401,11 +1401,25 @@ RSpec.describe SessionController do
             login: user.username, password: 'myawesomepassword'
+          expected_message = I18n.t('login.suspended_with_reason',
+                                    date: I18n.l(user.suspended_till, format: :date_only),
+                                    reason: Rack::Utils.escape_html(user.suspend_reason))
           expect(response.status).to eq(200)
-          expect(response.parsed_body['error']).to eq(I18n.t('login.suspended_with_reason',
+          expect(response.parsed_body['error']).to eq(expected_message)
+        end
+        it 'when suspended forever should return an error without suspended till date' do
+          user.suspended_till = 101.years.from_now
+          user.suspended_at = Time.now
+          user.save!
+          StaffActionLogger.new(user).log_user_suspend(user, "<strike>banned</strike>")
+          post "/session.json", params: {
+            login: user.username, password: 'myawesomepassword'
+          expected_message = I18n.t('login.suspended_with_reason_forever', reason: Rack::Utils.escape_html(user.suspend_reason))
GitHub sha: 1a8c949900993c229038916d6aeb0e319b470c41
This commit appears in #13776 which was approved by ZogStriP and eviltrout. It was merged by AndrewPrigorshnev.
