vagrant instructions incorrectly uses localhost (PR #53)
the ip address should match the one in ./Vagrantfile.
GitHub
localhost:4000 works fine for me.
works for me too…
AFAIK, it should be localhost, as that works for me. Is it not working for you on localhost?
ah, it was my fault. i should have waited a bit longer. i just noticed the port forwarding setup in Vagrantfile. vagrant is neat.
