WIP: FEATURE: Posts awaiting moderation (PR #14501)
Done :grin:
Any news?
Then you need to make sure the route is only visible when the user is the current user.
Yep, done!
This action requires to be logged-in and when trying to access it directly it results in the following message: Oops! That page doesn’t exist or is private.. So I guess we’re good :slightly_smiling_face:
do we actually need an alias here?
Mostly the question is: do we have to do this.set(“postUrl”, xxx) and expect it to mutate topic_url ?
Replaced by reads instead :slightly_smiling_face:
Mixing && and || in the same lines/conditions is hard to read (have to remember operators precedence).
Can you either add parenthesis around the && conditions or do one condition per line?
Ok I’ll revert the change :wink:
Added these dependencies as it seems to be The Right Way™ with Ember 3.15+ to test a lot of things (see Introduction - Testing - Ember Guides)
