[WIP] FEATURE: Rake task to uninstall theme (PR #10138)
This is a work-in-progress PR to allowing uninstalling a theme or a theme component via rake.
GitHub
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
https://meta.discourse.org/t/theme-component-upgrade-via-rake-not-working/152322/5
@chandandi If the only use case for this is updating a theme (by removing and re-installing), I would rather close this PR, as I fixed updating.
Thanks @markvanlan for the fix! I don’t see an option to close the PR. Could you do that if you have the access.
